[SOLVED] what are steps to see polarization in HFSS v 11 ( plz rpy early) ?
Chetali
Member level 1
i am following this steps,
Result > far field report > radiation pattern > gainLX for Eplane copolarization.
but nt getting results.:?:
Plz any1 tell me am i right?????????
& wt r steps to see H Plane polarization ???????:?:
Please reply as early as possible.
Thanking u in anticipation
what do you understand by gainLX plot? are you doing the sweep analysis while plotting the curves with frequency for set theta and phi?
yes, im using sweep.
but using this im getting only 180 degree results, other 180 remaining blank.
i have seen the co & cross polarization radiation pattern shows complete 360 degree.
Thanks in advance
hi,
To see linear polarization E plane result > Far field report > radiation pattern
set theta = all , phi = 0
gain, in category select gain phi n theta both.
same step to H plane only set phi = 90.
