Prince Vegeta
Member level 5
There's a new project I will work on, it's water level sensing from the residential water tank.
I want to output a percentage of available water, then do other stuff according to it. I will take care of everything else, the only thing I don't know about is what sensor to use?
the volume of the tank is 2m^3 (length=2m,width=1m,height=1m). so when I put a distance sensor to measure the height and say it's 40cm of water, this means 40% full and 60% empty, right? that's what I plan to do.
I want a cheap sensor (solution), about 30$ or so if possible (it's a simple residential device... if it's 50$, ok. but not more ^_^).
The device I'm gonna make will have more functions to do, but they depend on what current water level is.
Thanks for help.
Thanks for help.
