voltage to voltage conversion
tushar9
Newbie level 3
pune
can i use subtractor for conversion of 1-5v to 0-5v.
if yes pls anybody can explain how dose it works?
rply soon!!!!!!!!
For project application? How do you get the 1 volt in the circuit? I think by Just shorting the resistor provided there of which across you get the min 1 volt. That would reduce your voltage drop to 0 v.
Regards,
Jerin.
Hi tushar,
You can convert 1-5V to 0-4V.
Refer attached schematic.
If you want to convert 1-5V to 0-5V, you have to use DC-DC Converter.
Regards,
Viswanath
  • 1-5V to 0-4V.zip
