dann11
Full Member level 3
Hi! I want to use a P-channel MOSFET as a switch for my charger. The source terminal of the P-MOSFET is connected to the source of 20v, the drain is connected with a 14V battery and the gate terminal is controlled by Microcontroller PWM. I am thinking of using the voltage divider configuration , I am trying to simulate first but then I can't make the MOSFET turns off. What should I do? Any suggestion guys? Thanks.
