P.Copper
Member level 5
Hi y'all,
I have build 3 voltage divider circuits for sensing DC voltage, the output of this voltage dividers will then be fed to 3 analog channels of the dspic30f. the problem is once i interface the two circuits(voltage divider and dspic30f) the output voltage of 2 of the voltage dividers drops heavily. at first i thought it was a ground problem but i have a common ground for both circuits.
the adc of the dspic works fine without the voltage divider circuit I've checked it as well.
can anyone who might have came across this situation help. thanks
