rbolijn
Newbie level 2
Hi everyone,
I'm new on this forum, and i'm hoping for your help!
I'm currently working on the design of an ultrasonic sensor. I'm using a 40kHz ultrasonic transceiver (both receive and transmit). The transceiver is driven by a transformer with 1:10 turn ratio. Parallel to the transducer i want to implement a variable resistor with high resistance at the time of the ultrasonic burst (50kohm-100kohm) and low resistance just after the burst (500ohm - 1kohm) for probably around 0,1ms. Then the resistance should be high again in order for the received echo not to be damped.
I red quite a lot already about jfets as voltage controlled resistors. Still i'm finding it hard to find the right one. The drain will be grounded, the source will be an ac-signal (+30 volt to -30 volts) and the gate will be max 3,3 volts.
Do you guys have any ideas on which jfet to use?
