geozog86
Member level 3
Hello!
I want to model a cadence block (analog) and interact with the nearby analog blocks, but with a VHDL model (using VHDL AMS for that reason). The cadence block (cell) has many inputs (pins) but i will only model it as a buffer, output=input. So, i have this code:
Library (......)
ENTITY charge_1 IS
PORT(
TERMINAL SUPPLY3, AVSS : ELECTRICAL; //all the pins of the cadence cell, most are supposed to stay not-connected
TERMINAL ENBL : ELECTRICAL;
TERMINAL VBG, VFDBCK : ELECTRICAL
END ENTITY charge_1;
ARCHITECTURE FUNCTIONAL OF charge_1 IS
quantity vsupply across SUPPLY3 to AVSS;
quantity vvfdbck across VFDBCK to AVSS;
BEGIN
vsupplycp==vvfdbck;
END ARCHITECTURE FUNCTIONAL;
And for this simple implementation i got this error:
Error: The characteristic number (0) does not match the number of scalar equations (1) [LRM section
12.6.6]
which online found that implies that i have more equations than numbers i want resolved (which is zero!!!)
So i thought the problem was that i was leaving all the rest of the electrical nodes floating (not using them at all) so i created a signal called dummy1 where i just added the rest (bandgap etc that were not needed for the ideal buffer operation) but error remained.
Anyone has seen this problem? Or do you have any idea why this is not working? Thank you very much!
George
Library (......)
ENTITY charge_1 IS
PORT(
BEGIN
vsupplycp==vvfdbck;
12.6.6]
George
