verilog a code for 8 bit ideal ADC
tibusso
ireland
Hi all,
Can someone find the error in the following code?
module top;
wire in, clk, out;
ideal_adc i1(in,clk,out);
endmodule
module ideal_adc(in,clk,out);
input in,clk;
output [0:adc_size-1] out;
voltage in,clk,out;
parameter integer adc_size = 8 from [1:inf);
parameter real fullscale = 1.0;
parameter real delay_ = 0, trise = 10n, tfall = 10n;
parameter real clk_vth = 2.5;
parameter real out_high = 1, out_low = 0 from (-inf:eek:ut_high);
real sample,thresh;
real result[0:adc_size-1];
integer i;
analog
begin
@(cross(V(clk)-clk_vth, +1))
begin
sample = V(in);
thresh = fullscale/2;
for(i=adc_size-1;i>=0;i=i-1)
begin
if (sample > thresh)
begin
result = out_high;
sample = sample - thresh;
end
else result = out_low;
sample = 2*sample;
end
end
V(out) <+ transition(result,delay_,trise,tfall);
end
endmodule
Many thanks
Hi tibusso..
for this 8bit ideal ADC,it requires "dot H" files so can u provide me that "dot H" files...
so that errors can be removed....
thank u..
I do not understand the part concerning
sample =sample -threshold
and
sample = 2* sample
I think that we should check the input sample at different thresholds and no processing is done on the sample
please clarify
and
sample = 2* sample
It is the simple ideal successive approximation ADC (adc_8bit_ideal), copied - incorrectly - from the ahdlLib from c@dence.
Incorrect copy.
