Gizmotoy
Newbie level 5
I'm new to Verilog, but have a bunch of experience in VHDL. I'm trying to replicate something I accomplish with Generics in VHDL, but I'm having a bit of trouble.
I understand that you could define port widths in pre-2001 Verilog using something like:
However, can the same thing be accomplished using the new module syntax made possible in Verilog 2001? I prefer that syntax since it's more compact and keeps ports and types together, but I can't figure out how to make it work. I figured something like:
But of course it complains that WIDTH is undefined. If I move the parameter definition above the module definition it compiles, but crashes my simulator (Active-HDL).
Is there a way to use the new syntax with port widths based on parameters? I feel like I must be missing something obvious, but I just don't see it. Thanks!
module adder (a,b,c);
parameter WIDTH = 2; //defult value
input [WIDTH-1:0] a;
input [WIDTH-1:0] b;
output [WIDTH-1:0] c;
module adder (
input wire [WIDTH-1:0] a,
input wire [WIDTH-1:0] b,
output reg [WIDTH-1:0] c);
