jeevs
Hi All,
Most of the current environment present for verifying the micro controllers are directed ASM based one.Where the testing is done based on direct testcases features for each of the functionality.I would like to get rid of the ASM based environment using the system verilog & VMM.Use the available methods like constrained random based,I have to prove that the new features available is better off than the conventional directed testcases method used.
I need help in creating an verification architecture.As I have started the paper work here I need help as in the conventional method the ASM are converted to hex file which is preloaded into a memory from where the DUT takes on....IS there any work around or how this should be added in a CRT method.
Please give your valuable suggestions so that I can improve on my verification architecture.Are there any papers present on this please provide me what ever information that is available.
Regards,
Jeevs
Regards,
Jeevs
