negreponte
Member level 4
prime power px script
I am using design analyzer to execute my synthesys script.
The execution give me two files:
the sdf file and the verilog file.
I make a random simulation in modelsim to produce the vcd file.
Then I execute via prime power an other script which reads the verilog file and vcd
file
START OF FILE
#The following is a template PrimePower TCL file for the VCD/Verilog flow.
# 1. Comments are denoted with "#".
# 2. Tool default values are provided. They can be modified.
# 3. Users must replace the term "fillin" with appropriate options/values.
# 4. Refer to the man pages for detailed command information.
# Set Search Path / Library : (Can be placed in .pp_synopsys.setup)
# set search_path /usr/eda/libraries/tsmc013/synopsys
set target_library /usr/eda/libraries/tsmc013/synopsys/typical.db
set link_library /usr/eda/libraries/tsmc013/synopsys/typical.db
# Load Design and Activity Files
read_verilog -hdl_compiler /home/xxxxxx/Desktop/Synopsys_scripts/sbox1.v
#read_verilog -hdl_compiler /root/our_core/tb.v
current_design sbox
#current_design tb
link
#read_vcd -strip_path tb/mux1inst /root/our_core/mux1.vcd
#read_vcd -strip_path /root/our_core/tb.v /root/our_core/mux1.vcd
read_vcd /home/*******/Desktop/Synopsys_scripts/sbox1.vcd
# Apply Default Parameters
set hierarchy_separator /
set_input_transition .1 [all_inputs]
# Backannotation : Uncomment the commands which apply
# set_wire_load_model -name fillin
# read_parasitics wire.spef
# current_instance fillin
# source fillin
# Power Analysis and Waveform Generation
#set_operating_conditions fillin
set_waveform_options -interval 1 -file vcd -format fsdb
calculate_power -waveform
report_power -file vcd -threshold 0 -sortby power
# report capacitance
#report_wire fillin
END OF FILE
When I execute the script via primepower I Have the following warnings
The netXXX cannot be covered by vcd file(.SIM-220)
about 300 warnings
I tried to change simulation senario but I had the some problems.
When I see the cells tha they contribute in dynamic power. only the cells that they are connected in the output of the circuit give dynamic power.
Any suggestions???
file
START OF FILE
current_design sbox
#current_design tb
link
# source fillin
#report_wire fillin
END OF FILE
about 300 warnings
Any suggestions???
