It will be helpful if you provide more details on the things you tried, how the input supply to DC-DC converter is given, waveforms @ gates of Q1, Q2 and output waveform.
Moreover after supplying power the signal at L0 pin (IR2110 IC) is available. but no signal at Vs, Vb, & H0.
Across pin HIN and LIN, the signals are available.
I think diagram is not properly visible. You are right I connected SD,VSS and COM to ground and I replaced 1N4148 diodes with UF4007.
Inductor value is 400uH, 4A
Capacitor value is 100uF and 100V
Switching frequency is 300Hz
and Supply voltage to Drain terminal varies from 10 to 100V
The Vout has to be pulsating DC. If PWM signal duty cycle is 50% then output voltage should be 50% of input.
