Hello,
If you want to simulate such a structure in IE3D, you have to make the zero layer conductivity zero (in the basic parameters section). The ground plane as used in the antenna is just a metallic surface for IE3D. So if you are able to draw metallic surfaces in IE3D, you can just draw this ground plane as a polygon where the vertices are on different layers to create the V-structure.
