USB Programmer for ATMEGA32A
PA3040
Advanced Member level 3
Dear All,
As we all aware the MPLAB can use to program any PIC micro controller connected to PC via PICkit2 ( without using PICkit2 software)
What I need to know is ?
Can we program the ATMEGA32A Micro controller using AVR studio, as we can MPLAB
If can
What is the USB Programmer ( Any Schismatic )
Please help
Thanks in advance
You can program AVR microcontrollers from AVR Studio using a supported programmer (AVRISP or STK500) like the AVRISP mkII Programmer.
You can make an AVRISP compatible programmer such as this: **broken link removed**
Hope this helps.
Tahmid.
Reactions: PA3040
    PA3040
Dear Tahmid,
Thanks for the reply
Can I able to get the schematic for USB supported programmer to program and debug directly from AVR studio
Thanks in advance
http://www.elektor.in/sites/default/files/071035-Wu.pdf
Search Google for "AVRISP compatible USB programmer circuit" and ""AVRISP compatible USB programmer circuit Elektor". You'll get many results
Hope this helps.
Tahmid.
Reactions: PA3040
    PA3040
Dear Tahmid,
I decided to order the following USB Programmer. Please look at it and guide me.
Ca I able to program and debug using this programmer with AVR studio
Please help
Thanks in advance
No that will not be recognized in avr studio.
You will have to use an external program like avrdude
To debug you need a jtag device like jtag ice.
USBasp or AVRisp are just ISP programmers.
Here is a DIY JTAGICE but it only works in AVR studio 4 if I'm not mistaken and not in AVRstudio 6
https://www.edaboard.com/threads/165593/#post698499
Reactions: PA3040
    PA3040
Dear alexan_e
first I thought to verify the the meaning of this programmers
1.Jtag Programmer
2.JDM Programmer
What is the meaning of "J" here
What is the relation ship between serial port and "J"
What is the meaning of JDM and Jtag
Please advice
Thanks in advance
JTAG refers to
The AVR chips that have JTAG can either be programmed using ISP or JTAG and can be debugged using JTAG.
The chips that don't have JTAG (e.g. mega8) can only be programmed using ISP and can't be debugged
There is also a new alternative to debug for newer chips that support it, it is named debugwire https://en.wikipedia.org/wiki/DebugWIRE
There is of course the parallel programming option but is not very common unless there are problems using the ISP method.
I'm not sure about what JDM refers to.
Dear All ,
I decided to design AVR programmer debugger as attached cct
Please advice me I am on correct tract
Please advice
Thanks in advance
  • jtag (1).pdf
