Urgent!Please help!feed of print meander line antenna
xuanmogao
Newbie level 3
I have been simulated printed meander line antenna, according to the attached file.
But I do not understand the paper. It only shows the top side of the antenna. What is the back side of the antenna?
I simulated using figure 1. I can make it resonate at around 2.5 GHz, but the return loss is about -4db too high.
I think I may done something wrong. But I don't know where is the problem.
Also, there is a hollow arrow and dotted line in figure 1. What does them stand for? How can I feed the antenna?
Thanks a million!
  • the_effect_of_conductor_line_to_meander_line_antenna_design_5098.pdf
The other side is a whole sheet of metal covering the whole substrate (the ground)
it is a microstrip fed antenna and the other side must be the metalic gound plane I think
Thank you flashking! I simulated now as you said. The return loss at 2.4GHz is now around -10dB still too low. The paper said it should be -39dB. And my radiation pattern did not seem right. I attached my hfss file here.
Please!!! Could anyone help me to see where I was wrong? Thanks a million!!!
  • meander1.rar
I viewed the figure fast
a small notice, I didn't see integration line for the lumped port
also you can try the waveguide port instead
finally, did you simulate with a lossy or a lossless FR4 Substrate ?
