Unwanted Spikes at the result signal???
mohazaga
Full Member level 2
Full Member level 2
Hi,,,
I hope every body is ok , i have problem of design ckt , well I apply two inverted signal pulse (one delayed to other) to NAND gate .In the result there is some unwanted spikes since the output should be 0 as both signals are 1 (this is ok) but in other cases there are spike ? Why ? how to solve?
thanks
i dont know where the spikes appear , you can upload snapshot to clarify , but you may have two kinds of spike:
1- as output is zero except in one combination only, so spikes appear superimposed on the zero level, this cause of the rise & fall time of the two signals, you may notice that this spikes appears on transitions of inputs,and this might not cause a problem ,
2- spikes on while transition from zero to one i.e. the output comes to a higher level than Vdd (or the one level ), this also might not cause a problem as long as the spike value acceptable, it is in this case called overshoot, adding capacitances to the output may eliminate that but will increase your rise and fall time
Hi,,,
attached the Input/output waveforms of the NAND for more understanding of the problem, waiting.
thanks
Added after 5 hours 28 minutes:
Hi,,,
the following figure is the real output of the ckt (the outup is taken from NAND gate) where as the input is ideal delayed pulses.
thanks
sorry the snapshots too small to see :), i cant make them full size , if you can upload larger version , it will be better
Hi,,,
when I put noConn terminal on output node the spikes are reduced , what is taht mean?
thanks
