Shahzaib8412
There is no error when i compile it in ccs pic c when i run the proteus simulation model it gives an error.
if anybody is serious to help me in this situation i can send him proteus model
i dont know how to upload image here
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 #define LCD_RS_PIN PIN_B0; #define LCD_RW_PIN PIN_B1; #define LCD_ENABLE_PIN PIN_B2; #define LCD_DATA4 PIN_B3; #define LCD_DATA5 PIN_B4; #define LCD_DATA6 PIN_B5; #define LCD_DATA7 PIN_B6; #include <16F877A.h> #fuses HS,NOWDT,NOPROTECT,NOLVP #use delay(clock = 8000000) #include <lcd.c> #use fast_io(D) unsigned float Adc_values[5]; //ARRAY TO READ ADC VALUES unsigned float voltage; char A[15]; //CHARACTER ARRAY USED TO DISPLAY THE ADC VALUES int k=0; int x; //USED FOR BIT SHIFTING IN MOTOR PROGRAM int i=0; //USED IN FILTERING OF THE DATA int j=0; float Intensity=0; //TEMPERATURE LEVEL VARIABLE float Intensity1 = 0; int flag=0; void Motor(void){ //MOTOR DRIVER PROGRAM x=0b00000001; for (j = 0; j < 3000; j++){ PORTC = x; x = x << 1; Delay_ms(5); if( x==0b00010000){ x=0b00000001; } } } void SettingSFRs(){ TRISA=0xFF; TRISB.F0=1; TRISD.F0=0; //Sets the PORTD for Indicating Lights TRISD.F1=0; TRISD.F2=0; TRISD.F3=0; PORTD.F4=1; PORTD.F1=0; PORTD.F2=0; PORTD.F3=0; PORTD.F4=0; //Ending Indicating Lights Settings TRISC=0x00; //Sets PORTC as OUTPUT ANSEL=0xFF; //Sets the pin0-7 of ADC as analog input ANSELH=0x00; //Sets all other Analog Inputs to Digital ADCON0= 0b01000111; //Initializing the ADC Converter ADCON1 = 0x0E; INTCON=0b10010000; //Setting INTCON for External Interrupt C1ON_bit = 0; // Disable comparators C2ON_bit = 0; for (i = 0; i < 5; i++){ Adc_values[i] = Adc_values[i + 1]; } } void LCD(){ LCD_Init(); Lcd_Cmd(_LCD_CURSOR_OFF); Lcd_Out(1,4,"WELCOME"); Lcd_Out(2,4,"GROUP # 4"); Delay_ms(1000); Lcd_Cmd(_LCD_CLEAR); } void ReadValues(){ Lcd_Cmd(_LCD_CURSOR_OFF); for (i = 0; i < 4; i++){ Adc_values[i] = Adc_values[i + 1]; } Adc_values[4] = adc_Read(1); Delay_ms(200); voltage = 0; for (i = 0; i < 5; i++){ voltage += Adc_values[i]; } voltage /= 5; if(PORTD.F4==1){ Intensity=voltage/212.88; if ((Intensity1 + 0.250) > Intensity || (Intensity1 - 0.250) < Intensity ) { Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,3,"VOLTAGE"); Lcd_Out(2,15,"V"); Lcd_Out(2,4,A); } } if(PORTD.F4==0){ Intensity=voltage/1.9679; if ((Intensity1 + 0.250) > Intensity || (Intensity1 - 0.250) < Intensity ) { Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,3,"TEMPERATURE"); Lcd_Out(2,14,"C"); Lcd_Out(2,4,A); } } floatToStr(Intensity, A); Intensity1 = Intensity; Lcd_Out(2,4,A); } void interrupt (){ if(INTCON.INTF==1){ INTCON.INTE=0; flag=1; INTCON.INTE=1; INTCON.INTF=0; } } void IndicatingLights(){ if(Intensity>0 && Intensity<2){ PORTD.F0=1; PORTD.F1=0; PORTD.F2=0; } if(Intensity>2 && Intensity<4){ PORTD.F0=0; PORTD.F1=1; PORTD.F2=0; } if(Intensity>4&& Intensity<6 ){ PORTD.F0=0; PORTD.F1=0; PORTD.F2=1; } if(Intensity>15 && Intensity<20){ PORTD.F0=1; PORTD.F1=0; PORTD.F2=0; } if(Intensity>20 && Intensity<25){ PORTD.F0=0; PORTD.F1=1; PORTD.F2=0; } if(Intensity>25){ PORTD.F0=0; PORTD.F1=0; PORTD.F2=1; } } void main() { SettingSFRs(); LCD(); while(1){ PORTD.F3=~PORTD.F3; if(flag==1){ Lcd_Cmd(_LCD_CLEAR); Lcd_Out(1,1,"MOTOR RUNNING"); Motor(); flag=0; } ReadValues(); IndicatingLights(); } }
