shawnmk123
Junior Member level 3
I was designing a DC-DC converter with these requirements
Power available is 3mW.
Vin = 5V
Vout = 12V
1.Is operating the MAX1771 at 250uA load current (3mW/12V assuming 100% efficiency, Power in=Power out) a good idea? I am confused because on page 3, graph show that the efficiency drops below 80% if the current is less than 0.1A for bootstrapped operation for Vin=5V. On the other hand, the supply current vs supply voltage curve, shows that for Vin = 5V, input current = 0.4A --> load current will be lesser than 0.4A -->low efficiency. Please advise what these graphs mean ?
2. MAX1771 works on the PFM operation algorithm. After reading some material, I understand PFM seems to help avoid the operation of the
converter in DCM mode by operating in CCM till the converter reaches output voltage regulation. Yet, page 5 shows DCM operation for medium loads. With my specifications, I may be operating at light loads which implies deep saturation. Please explain.
3. Please suggest if design equations for the MAX1771 (PFM operation) is the same as a regular boost converter with PWM operation?
Thank you,
Vin = 5V
Vout = 12V
Thank you,
