bazook
Newbie level 5
Ive designed something and have very big problem. In ISE Synthesis finished without errors and warnings but when I viewed RTL Schematic there is one component not connected to others. I tried some combinations but nothing helps.
From this unconnected component, counter, I wanted use output value twice, so CNT_VAL was assigned to CNT_VAL_LOC and it was used in DDS and in gen_rect. I thought this is problem so Ive made two counters in this component, what you can see below but it doesn't work too.
entity top_adpll is
Port ( CLK : in STD_LOGIC;
CE : in STD_LOGIC;
INPUT : in STD_LOGIC;
OUTPUT : out STD_LOGIC_VECTOR (7 downto 0);
RESET : in STD_LOGIC
--ERROR : out STD_LOGIC
--AF : out STD_LOGIC_VECTOR (7 downto 0)
end top_adpll;
architecture Behavioral of top_adpll is
---------------------------Components---------------------------------------------------------------------------
component comparator is
Port ( WE : in STD_LOGIC;
WY : out STD_LOGIC;
CLK : in STD_LOGIC;
RESET : in STD_LOGIC;
CE : in STD_LOGIC);
end component;
component JK_ff is
CE : in STD_LOGIC;
J : in STD_LOGIC;
K : in STD_LOGIC;
Q : out STD_LOGIC);
end component;
component Counter is
Port ( CNT_VAL : out STD_LOGIC_VECTOR (7 downto 0);
CNT_VAL2 : out STD_LOGIC_VECTOR (7 downto 0);
CNT_INC : in STD_LOGIC;
CNT_INC2 : in STD_LOGIC;
CLK : in STD_LOGIC;
CE : in STD_LOGIC;
RESET : in STD_LOGIC);
end component;
component gen_rect is
CE : in STD_LOGIC;
STATE_LENGTH : in STD_LOGIC_VECTOR (7 downto 0);
RECT_VAL : out STD_LOGIC);
end component;
component DDS is
port(
CLK : in std_logic;
CE : in std_logic;
RESET : in std_logic;
PHASE : in std_logic_vector(7 downto 0);
SINE : out std_logic_vector(7 downto 0));
end component;
---------------------------Internal signals---------------------------------------------------------------------------
signal COMP_OUT_LOC : STD_LOGIC := '0';
signal JK_OUT_LOC : STD_LOGIC := '0';
signal CNT_VAL_LOC : STD_LOGIC_VECTOR (7 downto 0) := (others=>'0');
signal CNT_VAL_LOC2 : STD_LOGIC_VECTOR (7 downto 0) := (others=>'0');
signal CLK_LOC : STD_LOGIC := '0';
signal CE_LOC : STD_LOGIC := '0';
signal RESET_LOC : STD_LOGIC := '0';
signal WE_LOC : STD_LOGIC := '0';
signal RECT_VAL_LOC : STD_LOGIC := '0';
begin
--------Inputs--------------------------------------------
CLK_LOC <= CLK;
CE_LOC <= CE;
WE_LOC <= INPUT;
RESET_LOC <= RESET;
kom: comparator port map (CLK=>CLK_LOC, CE=>CE_LOC, RESET=>RESET_LOC, WE=>WE_LOC, WY=>COMP_OUT_LOC);
df: JK_ff port map (CLK=>CLK_LOC, CE=>CE_LOC, RESET=>RESET_LOC, J=>COMP_OUT_LOC, K=>RECT_VAL_LOC, Q=>JK_OUT_LOC);
licz: Counter port map (CLK=>CLK_LOC, CE=>JK_OUT_LOC, RESET=>RESET_LOC, CNT_INC=>'1', CNT_VAL=>CNT_VAL_LOC,CNT_INC2=>'1', CNT_VAL2=>CNT_VAL_LOC2);
gen: gen_rect port map (CLK=>CLK_LOC, CE=>CE_LOC, RESET=>RESET_LOC, RECT_VAL=>RECT_VAL_LOC, STATE_LENGTH=>CNT_VAL_LOC);
dco_dds: DDS port map (CLK=>CLK_LOC, CE=>CE_LOC, RESET=>RESET_LOC, PHASE=>CNT_VAL_LOC2, SINE=>OUTPUT);
end Behavioral;
