libyantiger
Member level 5
You should have a diode from your startup supply to the bias winding, and it should get reverse biased by the bias power, so that power does not keep coming through the power resistor after full startup.
Your bias winding should be powering the uc3845, not the power resistor.
You have actually described the proper startup method before.....when you said, dribble current through startup resistor , charge up startup capacitor, then uc3845 starts and then bias windig takes over.
try this
What about changing to ucc38c4x series, its pin-for-pin the same and drinks far less current.
What about using LR645
...IT SOUNDS LIKE THOUGH YOUR STARTUP RESISTOR IS TOO LOW OHMS, AND (sorry for caps) it is supplying chip all time. Again it sounds like your startup capacitor is not big enough....or your bias winding is not working....or your bias diode has died.
the bias winding is working fine ...it produces 12vdc ...i test it ...lets calculate 300vdc /30000 = 10ma
10ma*300vdc=3 watt ........oh ...my....god
my simlple calculation shows that resistor acoress such dc power with have to be 3 watt so it can handle current that is passing through
it never exceed limits?
or maybe just diode will sove it all since low drop 0.3 shoutcky can be installed and the resistor will still supply ..
but stilll i think if the winding working and it is working sir should not that put the load off the startup?
