[SOLVED] UART not working 18f25k22
ep.hobbyiest
Full Member level 4
I am using pic18f25k22 PIC and CCS Compiler. Code is working on proteus but not on real hardware.
Led blinking is working properly on hardware.
Here is the code.
#include <main.h>
void main()
   while(TRUE)
      //TODO: User Code
      printf("Live\r\n");
      delay_ms(1000);
and main.h file is as
#include <18F25K22.h>
#device ADC=16
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES NOBROWNOUT               //No brownout reset
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(internal=16MHz)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1)
No Oscillator fuses.
eg: HS, XT...
Finally got working. It was chip's problem. With other hardware this code is working.
