Tutorials/manuals for CST Microwave Studio
cst waveguide studio+video
I also have some tutorials on HFSS if anyone needs it just email me.
kosol
cst antenna rfid tutorial
May I know how to feed an SMA connector into a microstrip antenna in CST?
TQ!
cst em tutorial
you might want to look at the cst showrooms for tutotials?
That is where i pick up my basics in CST
tein cst tutorial
Piggy:
I had the same problem when i was designing Ultrawideband antenna arrays with CST microwave studio.Next to your antenna graphic window there is another minimized window with components in it.Some of the componenets that i remember included 50 ohms loads which you can attach to your antenna.
I hope thhis answers ypur question.
Re: CST Tutorial ???
any tutorials on Frequency Selective surface (unit cell) for CST MWS? help needed. thanks
thanks a lot for this job
Does anyone have any tutorials about parallel plate waveguide for CST?
CST Tutorial ???
Thanks mtts for the file.. it really help
CST Tutorial ???
hey i would like to some tutorial and examples on the discrete port definition? can anyone help?
CST Tutorial ???
I need simulate a leaky coaxial cable. Anyone helps me?
thank you very much ,does anybody have a CST tutorial about VBA
Hope this set of application notes on FSS are useful to you
  • cst_periodic array_fss.pdf
Hi guys:)
Have You got tutorial or description how to perform EM test on the PCBs?
Is it possible to import PCB then set the inputs and other parameters and visualize the electromagnetic field surrounding the board?
Many thanks for help:)
Yes, its possible using either Gerber import or loading the .dxf files.
Theoretically yes. You will need electrical models for all your components.
Thanks for reply:)
For the microcontrollers or something like this it could be hard:) But maybe it is possible to set capacitance, inductance and impedance of all inputs set one output clock and see the result:)?
Edit:
Now I don't think that something like this will be accurate:) Let's suppose that I've got only passive components and discrete elements and that for all PSPICE libraries. How to perform such a simulation?:) I've search a lot but now result:(
