turn on/off a heat lamp automatic
stonefox
Newbie level 2
Newbie level 2
Hello
I need to turn on/off a heat lamp, depending on what the temperature is.
Is that something exists which can be purchased ready to use, or should it special is produced?
Is for use outdoors.
Use a thermistor (PTC) as temperature sensor and an opamp as comparator (with a potentiometer on the non-inverting input as reference voltage). Once temperature exceeds a value set with the potentiometer, the opamp's output will go low and can switch off a relay that is connected to your lamp. Simple circuit, $2 worth of components.
