trying to make voltage to current converter
sudiipta
View attachment Volt to current.docHi, I am attaching a image for volt to current converter. I found it on some old thread here only.It looks like howland circuit with push-pull amplifier. My question: opamp o/p going to base of transistors. Emitter are shorted and we take output from there. Whether 390 ohm resistor which is actually connecting both base and emitters are correct in the diagram?
Here is my image URL or see the attached doc file
https://obrazki.elektroda.pl/64_1342748551.png
https://obrazki.elektroda.pl/64_1342748551_thumb.png
Thanks in advanced..I desperately need to build a bidirectional current source independent of load resistance.
The circuit looks correct. The 390 Ohm resistor is a good idea - it's to help with zero crossing.
R4 is not needed - it won't make any difference if you take it out.
You can do that if you're careful to match the diodes and transistors. You may have to use emitter resistor as well.
I prefer the circuit in post 1. It's simpler and allows higher output current.
Thank you..I will try it out and update
