EEPC
Newbie level 6
Hi all,
For LNAs what are good ways to stabilize the transistor at low frequencies? I'm working on an LNA and observe that its stability factor (K) is essentially 0 around f = 0 Hz (I'm using ADS to simulate K) and then quickly jumps up to a high value before coming down again. I'm wondering if what I'm seeing is just something weird happening in the simulation or if it means that the transistor is actually unstable at DC. I attached a picture of the K plot:
![Kfactor.JPG Kfactor.JPG](https://www.edaboard.com/data/attachments/18/18639-96b264c435b9957a809c83a6af64f540.jpg)
Note: K remains greater than 1 for all higher frequencies, so it's just in the range between 0 to ~90 MHz where it is below 1.
Right now my stabilizing network consists of some resistive loading at the drain (output) and some small source inductance. I find that if I add some loading at the gate (input) as well then K goes above 1 at lower frequencies, but this severely degrades my NF.
Any suggestions are welcome! Thanks.
