Transistor as voltage detector - Getting non-linear results
Freddybaby
Member level 4
California, USA
transistor voltage detector
I'm using an LM395 (High reliability transistor) as a simple threshold detector. The source is half wave rectified AC (from a current loop) and through a resistive divider into the gate via a 5K resistor to prevent oscillation (per datasheet).
The saturation point seems very non-linear as I vary the pot. Coule the diode be the culprit ?
single transistor voltage detector
because the output is essentially the transistor's Ic/Vbe curve, as is.
what you can do is to introduce a little bit of negative feedback to linearize that Ic/Vbe curve: put a small resistor between the emitter and the ground.
how to size it? well it depends on your design objectives.
    Freddybaby
threshold detector voltage
I got lazy and fixed this problem with a log function pot. Cheesy I know but it worked.. Thanks for the reply millwood
