mmuj
Junior Member level 3
Hi
my simple yet confusing question (at least to me) is, can audio transformer with 600 ohm primary and 600 ohm secondary winding be used in 50ohm primary 50ohm secondary circuit ?
little about back ground, I have to tx/rx data over 30 to 50 ohm coaxial cable using interface that is actually designed for 600 ohm line. I will change op amp output impedance by manipulating resistor & capacitor but do i need to change transformer as well ?
Actual transformer user is Midcom 82111 which is designed to reflect 600 ohm on primary(line side) with 470 ohm load on secondary (op amp side)
I asked similar question some time ago (search for "Modem coaxial cable interface") but i was diverted to do something else and now i am back to same problem so rather than cotinuing with the same thread i started new one
I will come to other aspect (not related to this problem) later
Thanks in advance
mmuj
Thanks in advance
mmuj
