Jadeit
Member level 5
Here in the discussion, I came across an LLC switched converter and I have no idea what a transformer with LL inductions looks like.
Here is a picture of a converter with details of a transformer and a resonant circuit.
The transformer is marked as TE65037, do you think it is the core of EE65?
I am interested in how a transformer with LL resonant coils on a common core is manufactured.
What can be found from the data revealed by the manufacturer?
a) n=9 The ratio of primary vs secondary winding is 9: 1
b) What is the resonant frequency? if C=54nF and Lr =20.32uH
f=1/(2*Pi*Sqrt(Cr*Lr)) about 152kHz, but manufcruter say 175kHz)
c) Ratio of total primary inductance to resonant inductance m
m=(Lr+Lm)Lr = 1
d) I assume that when all the coils are on the same core, the inductance ratio must match a quarter of the number of turns. And Np / Ns 9: 1
if Al=Lr/N^2 for Lr=20,32uH and N=12 is Al=151,9nH
Lr have 11 turn 20,32uH
Lm have 24 turn 96,7uH calculated
Lp have 27 turn 122,4uH calculated
Ls have 3 turn 1.5uH calculated
Is my reasoning correct?
A normal transformer would look something like this. The first primary winding 27 thread is either made of 0.3 mm CU tape or HF CU cable with 0.3 mm wire, current approx. 10A. Insulation barrier and 3 turns of Cu tape, current 63A. The winding orientation is identical
From what, how and where are Lr and Lm involved?
Lr is in series with Lp, so full current flows, so it must be from the same conductor as Lp, but how and where is it wound?
Lm has a lower end at the transformer terminal and the other must be connected between the end Lr and the beginning Lp, it is soldered to the transformer and from what, how and where is the winding Lm?
In short, what are the production instructions for the transformer with LL coils?
Thanks you
