yefj
Hello, From simulation i see that total current consumption is 16mA each opamp consumes 8mA.
i want to use FR-4 1.6mm thickness ,signal trace thickness is 1oz.
given these parameters i have tried to use the followong calculator shown below.
But the calculator asks for temperature rise.
What should i input in that parameter?
When i put 25C rise temperature is says that thar 0.001mm can handle 15mA.is it logical?
Thanks.
Thanks.
PCB Trace Width Conversion Calculator | DigiKey
Calculate the required trace width for a specified current using DigiKey's PCB Trace Width calculator.
www.digikey.com
