To program atmega64 is different than atmega8/16/32??
hardik.patel
Member level 5
I already using usbasp programmer for atmega8/16/32.
I am using programmer's notepad as compiler code n same for programe it. Also use sometime extreme burner for program.
So same method/style for atmega64 also??or what change?
if you worked with atmega8, 16 and 32, it's not different to use another atmega, just change in your makefile to target to an Atmega64 and you are done.
