To prevent reverse voltage flow
oppel
Newbie level 6
We will create a battery bundle with the values we want by connecting 2 batteries in series. We do not want the energy transfer between these serially connected batteries to be equal, and we do not want one to flow into the system more than the other. We do not want any short circuit events to occur. What kind of a PCB circuit can be created for this or would it be appropriate to use a diode?
I don´t understand at all.
Example:
This has neither to do with batteries nor whether they are connected in series or parallel. This is referenced to the load .. but you don´t speak about load and load conditions.
If you want to occur short circuits, then train the personal. But if you want to protect your circuit in case of short circuit, you obviously need a short circuit protection. In simplest case a fuse. Done billion times.
If you don´t want to use a fuse, then tell wha, and tell how you want it to operate. Current-time behaviour. Latching or non latching ... if latching, how do you want it to be reset? And so on. It´s your idea, so don´t hide your ideas ....
Sketches will be very helpful!
Klaus
Contact this author for paper on cell balancing : https://onlinelibrary.wiley.com/doi/full/10.1002/er.7053
Regards, Dana.
it shoud be "if you DON`T want to occur..."
You told a lot "We don´t want..." .. but you did not tell what you want.
Dana brought up "cell balancing". Surely a good idea. But from your posts I don´t see whether you are looking for cell balancing...
Klaus
LaTeX Commands Quick-Menu:
