throughput of a system in Qaurtus
fanwel
Full Member level 3
Dear all;
How to calculate the throughput of a system after successful compile the vhdl code in quartus?
Anyone familiar with this situatuion? Need helps. Thank You.
see I actually called this as bit rate calcuation.....so way that I had did is speed of clock * no of channel to transfer data .... e.g. 100 Mhz clock and 8 chanel will give you 100 * 8 bit transfer per second so bit rate is 800 mega bit....if is single clock sample
may be helpful to you....
Good Luck
Hi milind.a.kulkarni,
Is it the speed of clock is the frequency of a system? And how to know the number of channel?
Thank You for reply
Without knowing what the design does, you will have no chance of calculating this. You can calculate this value from the source code (and you know the clock speed, that you usually set yourself). Quartus is not needed.
Hi TrickyDicky,
Sorry for ask a stupid question, how to set the clock speed? I didn't do it before this.
Thank for reply
Usually on your board, you have a specific crystal. The clock speeds would usually be set during the specification phase, depeneding on what your interface is and how much throughput you need.
In my case sampling clock was 100Mhz .....however it was as same as system clock
