samuelr
Member level 4
Hi
I am trying to test my surge protector. I have a HV pulse generator which will give me a peak voltage of 15kV connected parallel to a 380VAC and inbetween is the TDK surge protector. There is 3kohm and 3.3mH in series.
When the 380VAC is absent (off) the pulse generator works nicely.
However its not going all the way to 10kV when the 380VAC is present (on)
I believe this should work and the firing of the pulse is at 0VAC of the 380VAC ( using zero-cross detect)
The best I am getting is 3kV which nearly not enough to do any damage on the surge protector or see how effective it is.
Any advise?
Any advise?
