triump.ar
Junior Member level 2
wt is the difference between the syntax in synopsys vs xilinx for if statment....when i m running the same program it works in xilinx but in synposys it is showing error....nyone has idea then plz tell ..
triump.ar said:wt is the difference between the syntax in synopsys vs xilinx for if statment....when i m running the same program it works in xilinx but in synposys it is showing error....nyone has idea then plz tell ..
