switched capacitor
kjohns
Newbie
Draw the output waveform Vout for the circuit shown below against time for a clock cycle of 5. Consider the Switches are Ideal and CA is equal to CB. (Ignore the Parasitic capacitance)
The upper transistor is P type.
The bottom transistor is N.
Current goes through capacitor CA first in one direction, then the other.
Do the above hints suggest what happens at the output? It may be unexpected since this circuit is seldom seen yet it's a useful building block circuit.
This sounds like a typical task for homework (you have just copied the task description).
And what is YOUR question?
