Presently aim using AD571 ADC.
It have fallowing futures.
Complete A/D Converter with Reference and Clock
Fast Successive Approximation Conversion: 40 ms max
No Missing Codes Over Temperature
08C to +708C: AD571K
–558C to +1258C: AD571S
Digital Multiplexing: Three-State Outputs
18-Pin Ceramic DIP
Low Cost Monolithic Construction
Operating on supplies of +5 V to +15 V and –15 V,
The AD571 accepts either unipolar (0 V to +10 V) or bipolar
(–5 V to +5 V) analog inputs by grounding or opening a
Single pin.
This ADC seems to be impressive because using an ADC of any embedded controller has the limitation of input voltage amplitude which although may be eleminated by incorporating a voltage divider but still there will be error in reading depending on how precise your voltage divided resistro network is.....
