Suggest me a book about embedded C programming
citizen
Member level 5
Member level 5
hi tiall,
any one can give me the suggesion to read which book for embedded "c"
programming
thank you
Re: started now
Wont get any specific book by any author on embedded C in the market because embedded C are compiler specific. What ever you get in the net are also specific to some compilers. So you should be clear to us by specifying which compiler you are using. But you can refer """"""mazidi's 8051"""""" which comes with assembly and embedded C specifically for c51 compilers. If you are using any other compiler then the help inthe compiler is the best help. Please specify the compiler.
    citizen
Re: started now
thank you for u r information im using unix plotform and c compiler
thank you
Re: started now
Can u please go to QNX.com. there you will get all the required materials or else i will send it on monday when i go to the office.
check out the website and tell if it was useful for you
