subtractor circuit using OP AMP
Arrowspace
Banned
Can some one explain how it is working
According to me it should be -4.5 Vdc
Your math is off. :wink: You apparently forgot about how R7 and R8 affect the non-inverting gain.
The voltage at the op amp (+) input is 2.5V, multiplied by the gain of the op amp, which is +2 (due to R7 and R8), giving an output of +5V for that input
The +7V at the minus input is multiplied by the op amp gain of -1, giving an output of -7V for that input.
Using superposition, the op amp output is thus -2V, exactly as you simulated.
Normally all values are equal for a unity gain differential amp ( 10K) to minimize offset from input bias current.
inverting gain= -R7/R8 *7V = (-1) * 7V
Non Inv gain = 1+ |inverting gain| * V+in= (1+1) * 5V*R5/(R5+R6)= (1+1) 5v * 1/2= 5v
Using superposition rules the output-7+5 =2 the difference.
As a check, the Vin-=Vin+ whenever the output is in the linear range ( not saturated)
