imtiaz369
Member level 1
Hello, good people. In HFSS, I'd like to subtract this empty rectangular wall from this solid rectangular object. However, if I subtract this using normal operations, the middle portion of the solid object remains on the design; I want to cut the entire middle section (even the middle section of the rectangular wall is an empty hole).
Is it possible in HFSS?
Thank you.
Thank you.
