[PIC] Stepper motor rotation using loop works only once
madhushan90
Newbie level 6
Newbie level 6
I am writing a code for move drill bit in x, y coordinates, when looping through x, y coordinates list two stepper motors are rotating only once, next coordinates are being ignored. Why this is happen? I am using MikroC for write the code. Also I am getting input from serial port. What could be the reasons for this situation. If anyone has similar project please give me suggestions, any help would be great. Thanks.
here is my code
#define speed 50
#define charLenth 6
#define xyLenth charLenth/2
#define roundPerCentimeter 1
char xCordinate[xyLenth];
char yCordinate[xyLenth];
int actualXLenth;
int actualYLenth;
int xValue1;
int xValue2;
int yValue1;
int yValue2;
int xNumRound; // how many rotate motor
int yNumRound; // how many rotate motor
int i;
int j = 0;
int k = 0;
char cordinate[charLenth];
int drillHeightRound =3;
int points = 0;
int fwdsteps = 0;
int bwdsteps = 0;
 void xStepperForward(int xRoundForwrd){
  for(i=1;i<xRoundForwrd+1;i++){
  portd = 1;
  delay_ms(speed);
  portd = 2;
  delay_ms(speed);
  portd = 4;
  delay_ms(speed);
  portd = 8;
  delay_ms(speed);
  portd = 1;
 void xStepperBackward(int xRoundBackwrd){
  for(i=1;i<xRoundBackwrd+1;i++){
  portd = 8;
  delay_ms(speed);
  portd = 4;
  delay_ms(speed);
  portd = 2;
  delay_ms(speed);
  portd = 1;
  delay_ms(speed);
  portd = 8;
 void yStepperForward(int yRoundForwrd1){
    for(i=1;i<yRoundForwrd1+1;i++){
  portd = 16;
  delay_ms(speed);
  portd = 32;
  delay_ms(speed);
  portd = 64;
  delay_ms(speed);
  portd = 128;
  delay_ms(speed);
  portd = 16;
 void yStepperBackward(int yRoundBackwrd){
    for(i=1;i<yRoundBackwrd+1;i++){
  portd = 128;
  delay_ms(speed);
  portd = 64;
  delay_ms(speed);
  portd = 32;
  delay_ms(speed);
  portd = 16;
  delay_ms(speed);
  portd = 128;
 void drillStepperForward(){
    for(i=0;i<drillHeightRound;i++){
  portb = 1;
  delay_ms(speed);
  portb = 2;
  delay_ms(speed);
  portb = 4;
  delay_ms(speed);
  portb = 8;
  delay_ms(speed);
  portb = 1;
 void drillStepperBackward(){
  portb = 8;
  delay_ms(speed);
  portb = 4;
  delay_ms(speed);
  portb = 2;
  delay_ms(speed);
  portb = 1;
  delay_ms(speed);
  portb = 8;
 void Read_Serial(){
  Delay_ms(100);                  // Wait for UART module to stabilize
  UART1_Write_Text("Enter X cordinate and Y cordinate : ");
  while (1) {                     // Endless loop
        for(i=0;i<charLenth;)
                    if(UART1_Data_Ready()) // if data ready
                        cordinate[i] = UART1_Read();
                          // read data
                        i++;
      break;
void main() {
  ADCON1 = 0x06; // To turn off analog to digital converters
  UART1_Init(9600);     // Initialize UART module at 9600 bps
  TRISC=0x81;        //input for RX Serial input
  PORTC=0x00;
  TRISD=0x00;        // Initialize motor X and y
  PORTD=0x00;
  TRISB=0x00;        //  Initialize motor drill
  PORTB=0x00;
  TRISA=0x00;
  PORTA = 0x00;
  Read_Serial();
  Delay_ms(100);
  points = sizeof(xCordinate)/sizeof(xCordinate[0]);
  for(i = 0; i < points; i++){
   if(i == 0)
            xNumRound = roundPerCentimeter*xCordinate[i] - '0';
            yNumRound = roundPerCentimeter*yCordinate[i] - '0';
            xStepperForward(xNumRound);
            Delay_ms(100);
            // stepper forword
            yStepperForward(yNumRound);
            Delay_ms(100);
    }else{
    //x logic
    if(xCordinate[i - 1] < xCordinate[i]){
       //forward
       fwdsteps = xCordinate[i] - xCordinate[i-1];
       xStepperForward(roundPerCentimeter*fwdsteps - '0');
    }else{
    //backward
        bwdsteps = xCordinate[i-1] - xCordinate[i];
        xStepperBackward(roundPerCentimeter*bwdsteps - '0');
You should not use delays for motors. Instead use Timer interrupts to generate the delays. You can use mikroE Timer Calculator tool for this. If you use delays then it becomes a blocking code and PIC will not be able to do other things when it is executing motor delays. If you have buttons then button press will not be detected when motor code is executing.
