Re: state diagram to check whether a serial data (msb first)
Its a typical digital design interview question.
The catch here is... if the length of the incoming serial stream is not fixed then it is impossible to find whether number is divisible by 5 or not.
It is so because the division operation is always performed for the LSB side of the number; hence if the number is MSB first with unknown width, it is mathematically impossible to ivide it by 5.
