Spice to cadence translation - Define vccs in cadence
femystika08
Newbie level 5
Hi guys,
I'm trying to translate the model of a this circuit from spice to cadence
* HP Memristor SPICE Model
* For Transient Analysis only
* created by Zdenek and Dalibor Biolek
* Ron, Roff  - Resistance in ON / OFF States
* Rinit  - Resistance at T=0
* D  - Width of the thin film
* uv  - Migration coefficient
* p  - Parameter of the WINDOW-function
*  for modeling nonlinear boundary conditions
* x  - W/D Ratio, W is the actual width
*  of the doped area (from 0 to D)
.SUBCKT memristor Plus Minus PARAMS:
+ Ron=1K Roff=100K Rinit=80K D=10N uv=10F p=1
* DIFFERENTIAL EQUATION MODELING *
Gx 0 x value={ I(Emem)*uv*Ron/D^2*f(V(x),p)}
Cx x 0 1 IC={(Roff-Rinit)/(Roff-Ron)}
Raux x 0 1T
* RESISTIVE PORT OF THE MEMRISTOR *
Emem plus aux value={-I(Emem)*V(x)*(Roff-Ron)}
Roff aux minus {Roff}
*Flux computation*
Eflux flux 0 value={SDT(V(plus,minus))}
*Charge computation*
Echarge charge 0 value={SDT(I(Emem))}
* WINDOW FUNCTIONS
* FOR NONLINEAR DRIFT MODELING *
*window function, according to Joglekar
.func f(x,p)={1-(2*x-1)^(2*p)}
*proposed window function
;.func f(x,i,p)={1-(x-stp(-i))^(2*p)}
.ENDS memristor
I want to use a voltage controlled voltage source vcvs and a voltage controlled current source vccs and my problem is how do I write a verilog-A module for your vccs given that it's gain depends on the current flow across the vcvs as shown in the attached image schema.png.
I have also attached the complete paper.
Thanks.
  • SPICE_memristor.pdf
