天线往事
Newbie
When I tried to simulate the Folded Shorted Dipole Antenna Array with Dual Circular Polarization, I met some problems. As you see from my model, I needed to build four antenna arms and two support posts, which were made of different materials. Among them, the antenna arm needs to pass through the support column, I designed the support column with a round hole and then passed the antenna arm through it, but the simulation reported an error, so how to solve this problem? I need you help.
