cxzeng
1. SOM(System-on-Module) Order Part Number
Part Number Pin# CPU Freq DDR2 SDRAM NAND Flash Ethernet Audio Note
SOM2416-I-400-64-256M
default:SOM2416-I 74 400MHz 64MB 256MB LAN9220 WM8731L For Samples/In stock/no MOQ[1] limited
SOM2416-I-400-64-256M-9221 74 400MHz 64MB 256MB LAN9221 WM8731L For Samples/In stock/no MOQ limited
SOM2416-I-400-64-256M-NENA 74 400MHz 64MB 256MB No No MOQ:10+pcs
SOM2416-II-400-64-256M
default:SOM2416-II 120 400MHz 64MB 256MB LAN9220 WM8731L For Samples/In stock/no MOQ limited
SOM2416-II-400-64-256M-9221 120 400MHz 64MB 256MB LAN9221 WM8731L For Samples/In stock/no MOQ limited
SOM2416-II-400-64-256M-NENA 120 400MHz 64MB 256MB No No MOQ:10+pcs
SOM2416-I-400-32-64M 74 400MHz 32MB 64MB LAN9220 WM8731L MOQ:50+pcs
SOM2416-I-400-64-1G 74 400MHz 64MB 1GB LAN9220 WM8731L MOQ:50+pcs
SOM2416-I-400-64-2G-9221 74 400MHz 64MB 2GB LAN9221 WM8731L MOQ:50+pcs
SOM2416-II-400-32-64M 120 400MHz 32MB 64MB LAN9220 WM8731L MOQ:50+pcs
SOM2416-II-400-64-1G 120 400MHz 64MB 1GB LAN9220 WM8731L MOQ:50+pcs
SOM2416-II-400-64-2G-9221 120 400MHz 64MB 2GB LAN9221 WM8731L MOQ:50+pcs
SOM2416-I-266-64-256M 74 266MHz 64MB 256MB LAN9220 WM8731L MOQ:10+pcs
SOM2416-I-266-32-64M-NA 74 266MHz 32MB 64MB LAN9220 No MOQ:50+pcs
SOM2416-II-266-64-256M-NE 120 266MHz 64MB 256MB No WM8731L MOQ:10+pcs
SOM2416-II-266-64-2G-9221 120 266MHz 64MB 2GB LAN9221 WM8731L MOQ:50+pcs
Note:
↑ Minimum Order Quantity
2. Development/Evaluation KIT Order Part Number
Part Number Note
KIT2416-I
or
KIT2416-II KIT2416-I and KIT2416-II is a necessary basic evaluation system kit for illustrating the functionality, connectivity of SOM2416-I/SOM2416-II modules on their each App Demo Board.
each KIT2416 includes
SOM2416-I(74pin,4x4cm) or SOM2416-II(120pin,4x4cm) Embedded Module
4.3" 16:9 TFT LCD, LED backlight digital adjustable, 480 x RGB x 272 pixels, with 4-wire resistance touch screen
Theirs corresponding App Demo Board Rev 1.1 having USB host and device/Ethernet/3 or 4 UART/IIC/SPI/LCD/touch screen/Stereo Audio out/MIC/Line in/SDMMC/ADC/PWM/GPIO/local bus interfaces
Cables : Ethernet cable, mini USB cable, RS232 Cable
Power Supply AC 110V~220V in DC 5V 1A output
SDK: WINCE 5.0 SDK and documents,App Demo Board's SCH, PCB source code; Linux SDK in under developing and planing Nov 2009 release
3.How to Order? One of the 3 ways:
Send Purchase Order mail to embed_sales at techor dot com and specifying Part#/Quantity/Where to Ship/Note , we will reply you the Quotation and payment instruction in 2 work days by e-mail
Add our services MSN: cxzeng at msn dot com , and chat/talk(in English and Chinese only) with our services to specify what your reqirements online
or you could refer to the official web page for detailed: SOM2416
Note:
Part Number Note
KIT2416-I
or
