Libin
Junior Member level 2
Kindly give the concept of a wide range SMPS. The SMPS should work from an input voltage of 10V- 40VDC as well as 85-265VAC..So effectively from 10V DC to 350VDC. The output voltage requirement is 12V ( If 12V is not possible outputs can be 7V also ) Total output power is 10W. Please help me by sending valuable suggestions/ Clues or ideas.
Regards,
Libin
Regards,
Libin
