nanorobot
Newbie level 6
Hi
I'm designing a two-layer pcb with an RF module on it ( ). I'm connecting the module to an antenna (1/4 wave dipole) using an sma connector (https://www.tme.eu/en/details/sma-13/sma-smb-smc-connectors/# ) and a 50 ohm microstrip line. My frequency of operation is 868 MHz. I'd like to place the sma connector on the top layer side of the pcb but I think two problems will arise.
The first one: although the impedance of the microstrip line will be 50 ohm for most of its length, it won't be 50 ohm when entering the sma connector. This problem is exactly the same (except for smaller sma and lower frequency) as the one I found on this blog: https://www.rowetel.com/blog/?p=147.
The second one: Since the sma connector is placed on the top layer the antenna doesn't directly "see" the bottom layer RF ground plane. The ground plane is obstructed by top layer components and traces.
Well, I'd like to know if I can place my sma connector this way. I mean, will the rf performance be seriously compromised by doing so? Or should I definetely avoid this kind of configuration and place the sma on the botom layer side?
Thank you very much for any practical advice because I'm completely at a loss :sad:
