I made single phase inverter and the output waveform i have seen in DSO. Please share your views is it correct output or some modification are require?
I'm not familiar with inverter, but doesn't it should be a sinusoidal type waveform around a steady DC bias level? Yours seems like the "duty cycle or control signal" waveform.
