Sine function generator (VHDL)
FlyingDutch
Advanced Member level 1
Bydgoszcz - Poland
Hello,
I need for resolving Forward/Inverse kinematics problem (in context for robotic arm) to calculate trigonometric functions values. I am going to use in every arm joint quadrature encoders (optical) width 10-bit resolution. Because this arm will have seven joints (seven degree of fridom) I decided to make a controller for arm based on FPGA circuit (I known that this task is also workable on microcontroller), mostly for educational purpose (learning myself settlement of problems using FPGA).
So first of all, these are assumptions:
1) The angle is given width 10-bit resolution for full period of sine function (2PI or 360 degrees are divided for 1024 ranges)
2) Returned values of sine function are in "IEEE-754 Single Precision" format (32-bit float number)
3) Sine function values are stored in ROM memory (FPGA BRAM bank) for a one quarter of full period.
First of all to accomplish this task, I wrote a simple program (Borland C++ Builder 6) for generation sine function table in "IEEE-754 Single Precision" format. This application is generating output that we can past direct to coe file (ROM memory content). See screenshot:
Here is content of coe file (BRAM ROM memory) generated by this application for 10-bit resolution of full period - 256 values for a quarter of sine function. The values are 32-bit floating point numbers written in binary:
memory_initialization_radix=2;
memory_initialization_vector=
00000000000000000000000000000000,
00111011110010010000111110001000,
00111100010010010000111010010000,
00111100100101101100100110110110,
00111100110010010000101010110000,
00111100111110110100100110111010,
00111101000101101100001100101100,
00111101001011111110000000000111,
00111101010010001111101100110000,
00111101011000100001010001101001,
00111101011110110010101101110100,
00111101100010100010000000001010,
00111101100101101010100100000101,
00111101101000110011000010001100,
00111101101011111011011010000001,
00111101101111000011101011000100,
00111101110010001011110100110110,
00111101110101010011110110111010,
00111101111000011011110000101111,
00111101111011100011100001110111,
00111101111110101011001001110011,
00111110000000111001010100000010,
00111110000010011100111110000111,
00111110000100000000100010110111,
00111110000101100100000010000100,
00111110000111000111011011011110,
00111110001000101010101110110110,
00111110001010001101111011111100,
00111110001011110001000010100010,
00111110001101010100000010011000,
00111110001110110110111011001111,
00111110010000011001101100111000,
00111110010001111100010111000010,
00111110010011011110111001100000,
00111110010101000001010100000010,
00111110010110100011100110011000,
00111110011000000101110000010100,
00111110011001100111110001100110,
00111110011011001001101010000000,
00111110011100101011011001010001,
00111110011110001100111111001100,
00111110011111101110011011100001,
00111110100000100111110111000001,
00111110100001011000011011001111,
00111110100010001000111010010011,
00111110100010111001010100000111,
00111110100011101001101000100010,
00111110100100011001110111011110,
00111110100101001010000000110010,
00111110100101111010000100010111,
00111110100110101010000010000110,
00111110100111011001111001111000,
00111110101000001001101011100101,
00111110101000111001010111000101,
00111110101001101000111100010010,
00111110101010011000011011000100,
00111110101011000111110011010100,
00111110101011110111000100111010,
00111110101100100110001111101111,
00111110101101010101010011101100,
00111110101110000100010000101010,
00111110101110110011000110100001,
00111110101111100001110101001010,
00111110110000010000011100011110,
00111110110000111110111100010110,
00111110110001101101010100101010,
00111110110010011011100101010011,
00111110110011001001101110001011,
00111110110011110111101111001010,
00111110110100100101101000001010,
00111110110101010011011001000010,
00111110110110000001000001101100,
00111110110110101110100010000001,
00111110110111011011111001111001,
00111110111000001001001001001111,
00111110111000110110001111111011,
00111110111001100011001101110101,
00111110111010010000000010111000,
00111110111010111100101110111011,
00111110111011101001010001111001,
00111110111100010101101011101010,
00111110111101000001111100001000,
00111110111101101110000011001011,
00111110111110011010000000101101,
00111110111111000101110100100111,
00111110111111110001011110110011,
00111111000000001110011111100100,
00111111000000100100001010110001,
00111111000000111001110000111101,
00111111000001001111010010000100,
00111111000001100100101110000011,
00111111000001111010000100110110,
00111111000010001111010110011011,
00111111000010100100100010101110,
00111111000010111001101001101011,
00111111000011001110101011010001,
00111111000011100011100111011010,
00111111000011111000011110000101,
00111111000100001101001111001101,
00111111000100100001111010110000,
00111111000100110110100000101011,
00111111000101001011000000111001,
00111111000101011111011011011001,
00111111000101110011110000000111,
00111111000110000111111111000000,
00111111000110011100001000000001,
00111111000110110000001011000110,
00111111000111000100001000001100,
00111111000111010111111111010010,
00111111000111101011110000010010,
00111111000111111111011011001011,
00111111001000010010111111111001,
00111111001000100110011110011001,
00111111001000111001110110101001,
00111111001001001101001000100101,
00111111001001100000010100001010,
00111111001001110011011001010110,
00111111001010000110011000000101,
00111111001010011001010000010101,
00111111001010101100000010000010,
00111111001010111110101101001010,
00111111001011010001010001101010,
00111111001011100011101111011110,
00111111001011110110000110100101,
00111111001100001000010110111011,
00111111001100011010100000011101,
00111111001100101100100011001001,
00111111001100111110011110111100,
00111111001101010000010011110011,
00111111001101100010000001101100,
00111111001101110011101000100011,
00111111001110000101001000010110,
00111111001110010110100001000010,
00111111001110100111110010100101,
00111111001110111000111100111011,
00111111001111001010000000000011,
00111111001111011010111011111001,
00111111001111101011110000011100,
00111111001111111100011101100111,
00111111010000001101000011011010,
00111111010000011101100001110001,
00111111010000101101111000101001,
00111111010000111110001000000001,
00111111010001001110001111110101,
00111111010001011110010000000100,
00111111010001101110001000101010,
00111111010001111101111001100101,
00111111010010001101100010110100,
00111111010010011101000100010011,
00111111010010101100011101111111,
00111111010010111011101111111000,
00111111010011001010111001111010,
00111111010011011001111100000011,
00111111010011101000110110010000,
00111111010011110111101000100000,
00111111010100000110010010110000,
00111111010100010100110100111101,
00111111010100100011001111000111,
00111111010100110001100001001001,
00111111010100111111101011000011,
00111111010101001101101100110010,
00111111010101011011100110010011,
00111111010101101001010111100101,
00111111010101110111000000100110,
00111111010110000100100001010011,
00111111010110010001111001101010,
00111111010110011111001001101010,
00111111010110101100010001010000,
00111111010110111001010000011010,
00111111010111000110000111000111,
00111111010111010010110101010011,
00111111010111011111011010111110,
00111111010111101011111000000110,
00111111010111111000001100100111,
00111111011000000100011000100001,
00111111011000010000011011110010,
00111111011000011100010110011000,
00111111011000101000001000010000,
00111111011000110011110001011010,
00111111011000111111010001110011,
00111111011001001010101001011001,
00111111011001010101111000001100,
00111111011001100000111110001000,
00111111011001101011111011001101,
00111111011001110110101111011000,
00111111011010000001011010101000,
00111111011010001011111100111100,
00111111011010010110010110010001,
00111111011010100000100110100111,
00111111011010101010101101111011,
00111111011010110100101100001100,
00111111011010111110100001011000,
00111111011011001000001101011111,
00111111011011010001110000011110,
00111111011011011011001010010011,
00111111011011100100011010111111,
00111111011011101101100010011110,
00111111011011110110100000110000,
00111111011011111111010101110011,
00111111011100001000000001100111,
00111111011100010000100100001000,
00111111011100011000111101010111,
00111111011100100001001101010011,
00111111011100101001010011111000,
00111111011100110001010001001000,
00111111011100111001000100111111,
00111111011101000000101111011110,
00111111011101001000010000100010,
00111111011101001111101000001011,
00111111011101010110110110010111,
00111111011101011101111011000110,
00111111011101100100110110010111,
00111111011101101011101000000111,
00111111011101110010010000010111,
00111111011101111000101111000101,
00111111011101111111000100010001,
00111111011110000101001111111000,
00111111011110001011010001111011,
00111111011110010001001010011000,
00111111011110010110111001001110,
00111111011110011100011110011110,
00111111011110100001111010000100,
00111111011110100111001100000010,
00111111011110101100010100010110,
00111111011110110001010010111111,
00111111011110110110000111111100,
00111111011110111010110011001101,
00111111011110111111010100110001,
00111111011111000011101100101000,
00111111011111000111111010110000,
00111111011111001011111111001001,
00111111011111001111111001110011,
00111111011111010011101010101100,
00111111011111010111010001110101,
00111111011111011010101111001100,
00111111011111011110000010110001,
00111111011111100001001100100100,
00111111011111100100001100100011,
00111111011111100111000010110000,
00111111011111101001101111001001,
00111111011111101100010001101101,
00111111011111101110101010011101,
00111111011111110000111001011000,
00111111011111110010111110011110,
00111111011111110100111001101101,
00111111011111110110101011000111,
00111111011111111000010010101011,
00111111011111111001110000011001,
00111111011111111011000100001111,
00111111011111111100001110001111,
00111111011111111101001110011000,
00111111011111111110000100101001,
00111111011111111110110001000011,
00111111011111111111010011100110,
00111111011111111111101100010001,
00111111011111111111111011000100
To getting to a point we want to calculate sine function width resolution 10-bit (values from 0 to 1023). So the angle is given width formula:
angle = n * 0,00613592332229018 (Radians)
where: 0,00613592332229018 (in radians is angle gain)
and n is sample number (from 0 to 1023) - which is corresponding full angle (2*PI radians of 360 degrees) See the picture:
As we can see when one have sine table for one quarter he can calculate it's values for full period (2*PI in radians or 360 degrees). On the picture is distinquished how have to change 8-bit address (values 0 to 255) of ROM memory (in which is stored sine table for one quarter). One also can see thatr the second half (above PI or 180 degrees) sine function values are identical as in first half, but width negative sign.
What's your question?
It's not clear, which calculations you want to perform in FPGA, but using floating point numbers is generally no good idea. Better use fixed point numbers (signed or unsigned integer values with implied power of two scaling factor).
Hello,
here is next part of this post:
To make sine function generator in VHDL we need two components:
  1. ROM memory width sinus table for one quarter
  2. Compnent which is changing angle 10 bit (values 0 to 1023) to corresponding values of 8 bit adresses of ROM memory
Here are project sources files in VHDL (for FPGA Artix-7) - Xilinx Vivado2018.2.
The main entity (top module) is "SineFunction":
entity SineFunction is
    Port ( clk : in STD_LOGIC;
           reset : in STD_LOGIC;
           strobe : in STD_LOGIC;
           angle : in STD_LOGIC_VECTOR (9 downto 0);
           SineValue : out STD_LOGIC_VECTOR (31 downto 0); --Sine function value in IEEE-754 Single Precision (Float32)
           Sign : out STD_LOGIC); -- Sign: 0 positive, 1 negative
end SineFunction;
As one can see we have clock, reset pin, strobe signal (High state on strobe returns sine value for given angle):
angle - 10 bit values from 0 to 1023
SineValue - value of sine function as 32 bit float number
Sign - sign of sine function: 0- positive, 1 -negative
and here is full code of "SineFunction.vhd":
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
end SineFunction;
architecture Behavioral of SineFunction is
   component SinProject is
              Kat : in  STD_LOGIC_VECTOR (9 downto 0);
              AddressSinus : out  STD_LOGIC_VECTOR(7 DOWNTO 0);
              ZnakSinus : out integer range -1 to 1
   end component;
   component SineTable_ROM is
     Port (
       clka : in STD_LOGIC;
       ena : in STD_LOGIC;
       addra : in STD_LOGIC_VECTOR ( 7 downto 0 );
       douta : out STD_LOGIC_VECTOR ( 31 downto 0 )
   end component;
   signal  OutAddressSinus : STD_LOGIC_VECTOR(7 DOWNTO 0);
   signal  OutZnakSinus :  integer range -1 to 1;
   signal  SinOut32Float : STD_LOGIC_VECTOR ( 31 downto 0 );
begin
  C1: SinProject port map (clk, reset, strobe, angle, OutAddressSinus, OutZnakSinus);
  C2: SineTable_ROM port map (clk, strobe, OutAddressSinus, SinOut32Float);
  SEQ1: process (clk, OutZnakSinus, SinOut32Float)
   begin
     if (rising_edge(clk)) then
       if (OutZnakSinus > 0) then
         SineValue <= SinOut32Float;
         Sign <= '0';
       else
         SineValue <= (b"1" & SinOut32Float(30 DOWNTO 0));
         Sign <= '1';
       end if;
     end if;
   end process;
end Behavioral;
Component "SinProject" changes 10-bit angle (360 degrees) into 8 bit address (0 to 255) for reading values from ROM. Here is full code of "SinProject.vhd":
library IEEE;
use ieee.std_logic_unsigned.all;
-- any Xilinx primitives in this code.
--library UNISIM;
entity SinProject is
end SinProject;
architecture Behavioral of SinProject is
  signal KatUnsigned : unsigned(9 downto 0); -- definicja syg lokalnego
  signal AddressUnBig : unsigned(9 downto 0); -- definicja syg lokalnego
  signal AddressUnsigned : unsigned(7 downto 0); -- definicja syg lokalnego
begin
  SEQ: process (reset, clk, strobe, Kat)
  begin
    if rising_edge(clk) then
       if (reset = '0') then
	     AddressSinus <= b"00000000";
       elsif (strobe = '1') then
         KatUnsigned <= unsigned(Kat);
		 if (KatUnsigned < 256) then
		    AddressUnsigned <= KatUnsigned(7 DOWNTO 0);
			AddressSinus <= std_logic_vector(AddressUnsigned);
			ZnakSinus <= 1;
		 elsif ((KatUnsigned >= 256) and (KatUnsigned < 511)) then
		    AddressUnBig <= (254-(KatUnsigned-256));
		    AddressUnsigned <= AddressUnBig(7 DOWNTO 0);
			ZnakSinus <= 1;
		 elsif ((KatUnsigned >= 511) and (KatUnsigned <= 766)) then
		    AddressUnBig <= (KatUnsigned-511);
			ZnakSinus <= -1;
		 elsif ((KatUnsigned >= 767) and (KatUnsigned < 1023)) then
		    AddressUnBig <= (255-(KatUnsigned-767));
			ZnakSinus <= -1;
		else
		end if;
    end if;
   end if;  -- if rising_edge(clk) then
  end process;
end Behavioral;
The last component is "SineTable_ROM":
     Port (
       ena : in STD_LOGIC;
It had been generated using free Xiluinx IPCore(Memory generator) as ROM memory (in FPGA BRAM block).
In file "SinProjecttestBench.vhd" is full behavioral simulation of full project:
-- Company:
-- Engineer:
-- Create Date:   11:08:25 08/04/2019
-- Design Name:
-- Module Name:   C:/Users/mgabr/Spartan6/SinusCosinusFunction01/SinprojecttestBench.vhd
-- Project Name:  SinusCosinusFunction01
-- Target Device:
-- Tool versions:
-- Description:
-- VHDL Test Bench Created by ISE for module: SinProject
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
-- Notes:
-- This testbench has been automatically generated using types std_logic and
-- std_logic_vector for the ports of the unit under test.  Xilinx recommends
-- that these types always be used for the top-level I/O of a design in order
-- to guarantee that the testbench will bind correctly to the post-implementation
-- simulation model.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
--USE ieee.numeric_std.ALL;
ENTITY SinprojecttestBench IS
END SinprojecttestBench;
ARCHITECTURE behavior OF SinprojecttestBench IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT SineFunction is
    END COMPONENT;
   --Inputs
   signal clk : std_logic := '0';
   signal reset : std_logic := '0';
   signal angle : std_logic_vector(9 downto 0) := (others => '0');
   signal strobe : std_logic := '0';
   --Outputs
   signal SineValOut : STD_LOGIC_VECTOR(31 DOWNTO 0);
   signal Signout : STD_LOGIC;
   -- Clock period definitions
   constant clk_period : time := 100 ns; --10 Mhz
BEGIN
	-- Instantiate the Unit Under Test (UUT)
   uut: SineFunction PORT MAP (
          clk => clk,
          reset => reset,
          strobe => strobe,
          angle => angle,
          SineValue => SineValOut,
          Sign => Signout
   -- Clock process definitions
   clk_process :process
   begin
		clk <= '0';
		wait for clk_period/2;
		clk <= '1';
   end process;
   -- Stimulus process
   stim_proc: process
   begin
      -- hold reset state for 100 ns.
      wait for 100 ns;
      wait for clk_period*10; --1us
      -- insert stimulus here
        reset <= '0';
		strobe  <= '0';
		angle <= b"0000000000";
		wait for 1 ms;
		reset <= '1';
		strobe  <= '1';
		wait for 1 ms;
		strobe  <= '0';
		wait for 1 ms;
		angle <= b"0000000001";
		strobe  <= '1';
		wait for 1 ms;
		strobe  <= '0';
		wait for 1 ms;
		angle <= b"0010000000"; --128
		strobe  <= '1';
		wait for 1 ms;
		strobe  <= '0';
		wait for 1 ms;
		angle <= b"0011111111"; --255
		strobe  <= '1';
		wait for 1 ms;
		strobe  <= '0';
		wait for 1 ms;
		angle <= b"0100000000"; --256
		strobe  <= '1';
		wait for 1 ms;
		strobe  <= '0';
		wait for 1 ms;
        angle <= b"0101110010"; --370
        strobe  <= '1';
        wait for 1 ms;
        strobe  <= '0';
		wait for 1 ms;
		angle <= b"0111111111"; --511
		strobe  <= '1';
		wait for 1 ms;
        strobe  <= '0';
        wait for 1 ms;
        angle <= b"1000000000"; --512
        strobe  <= '1';
        wait for 1 ms;
        strobe  <= '0';
        wait for 1 ms;
        angle <= b"1011111000"; --760
        strobe  <= '1';
        wait for 1 ms;
        strobe  <= '0';
        wait for 1 ms;
        angle <= b"1110000100"; --900
        strobe  <= '1';
	    wait for 1 ms;
        strobe  <= '0';
        wait for 1 ms;
        angle <=b"1111111111"; --1023
        strobe  <= '1';
      wait;
   end process;
END;
Here is screenshot width results of simulation:
To ease I set that SineValue is displayed as decimal number in 32-bit float value. As one can see returned sine values are proper for given angles.
In zip archive I attached ful project - Vivado 2018.2.
View attachment SinusCosTestProj01.zip
Any comments and proposals of improvements are warmly welcome :p
Jind regards
I am aware of that. I am going to calculat all Forward/Inverse kinematics problem related to robotic arm on FPGA circuit. Fixed-point numbers arte not very convenient for such calculations even if wide range of values of results. This is the reason why I had written my own module for calculating sine function values.
I had tested efficient module of 4 floating point operation which is not occupying many resources of FPGA fabric.
On open cores were few projects of calculating sine function but all fixed-point.
Basically I would like to use this module to calculations involved in converting angles from seven quadrature encoders to X,Y,Z coordinates of arm end.
Kind regards
I'd use fixed point, too.
For a 10 bit resolution input ... why do you need floating point? What benefit do you expect?
I even doubt if a more than 16 bits (optimally scaled) give a benefit.
Please do an error calculation first..
Klaus
Klaus
Hello Klaus,
I don't want to argue width your arguments - I agree with all of them, but on the contrary why not?
What argumenst are against to use floating-point: occupation of FPGA resources or speed? In this scenario speed is more than enough even when calculations are made in floating point.
Kind Regards
I presume that you have more than one FP calculation in your signal flow. You have to instantiate the FPU many times, or implement the controller as sequential machine, similar to calculation in a regular processor. I don't know if your concept takes this direction. Not impossible, but you are loosing many advantages of parallel FPGA data processing.
As previously mentioned, there will be an error propagation from angle to magnitude. It sets an upper limit to useful magnitude resolution. You are presenting an isolated sine table unit right now. The resolution requirements are however defined by the overall controller application. Without analyzing it, you can't make substantiated specifications for the sine function unit.
What arguments are against to use floating-point: occupation of FPGA resources or speed?
In your application, probably both.
Over the years, I had a very few FPGA designs that were dealing with floating point numbers. It's usage was always dictated by external data interface specifications, never useful for the respective signal processing task on its own.
New trends in High-End FPGAs - EEJournal arti8cle
Hello Guys,
I am just reading article from EEJournal titled "High-End FPGA Showdown – Part 1 A Tale of Three Cities". Here is link to this article:
https://www.eejournal.com/article/high-end-fpga-showdown-part-1/
Article is very interesting, desrcibes new features in last High-End FPGAs from Xilinx, Intel, Achronix. One of these features intrigued me, here is quotation from this article:
All three vendors now offer hardened support for floating point. Achronix has a completely new architecture for their DSP blocks, which they call “Machine Learning Processors” (MLPs). Each MLP contains up to 32 multiplier/accumulators (MACs), 4- to 24-bit integer modes, and various floating-point modes, including native support for Tensorflow’s Bfloat16 format as well as block floating-point format. Most importantly, the Achronix MLP couples embedded memory blocks tightly with the arithmetic units, allowing the MAC operations to run at full 750 MHz without getting hung up waiting for memory through the FPGA fabric.
Intel also uses variable precision DSP blocks with hardware floating-point (essentially like they’ve offered for years in their FPGAs). Intel’s floating point support is perhaps the broadest and most mature of the three. With Agilex, they have introduced two new floating-point modes, half-precision floating-point (FP16) & Block floating-point (Bfloat16), and they have made architectural adjustments to make their DSP operations even more efficient.
Xilinx has upgraded their previous DSP48 slices to DSP58 – presumably because they now include hardware floating-point, and their multipliers are upgraded to 27×24. So, with this generation, the other two vendors have joined Intel in offering hardware floating-point support. This is a reversal for Xilinx, who previously claimed that floating point support in FPGAs was a bad idea because floating point is primarily used for training, and FPGAs will primarily target inference.
In terms of what floating point formats are available, FP32 is supported by Versal (with up to 2.1K multipliers) and Agilex (with up to 8.7K multipliers). Half-precision (FP16) is supported by all three families – Versal with up to 2.1K multipliers, Agilex with up to 17.1K multiplers, and Speedster with up to 5.1K multipliers. Bfloat16 is supported by Agilex (with up to 17.1K multipliers) and Speedster (with up to 5.1K multipliers). For FP24, Versal and Agilex would presumably use the FP32 units, and Speedster has up to 2.6K multipliers. Achronix Speedster also supports up to 81.9K multiplers for block floating point.
The previous speakers in this thread demonstrated that using floating-point arithmetic is ineffectual in context of FPGAs. And I of course agree with this thesis. So I am wondering why hardware floating-point blocks are present in newest High-End FPGAs from three biggest FPGA vendors. As far as I know the fixed-point arithmetic is enough for learning of artificial neural networks? So what is purpose of these floating-point DSP block, and what benefits they bring.
Kind Regards
Sorry I would like to place this post in thread:
https://www.edaboard.com/showthread.php?385967-Sine-function-generator-(VHDL)
Could I ask administrator to move this post to this thread?
Thanks and Regards
