Simulation hanging.... What can be the causes..?
vinun_7
Junior Member level 2
My question is related to verification.
If u r running a simulation (module level or full chip) and u have already made sure that
- clk/reset and other connectivities are okay
- the chip has booted properly
But the simulation hangs.
- Ur simulation time is not proceeding only delta is proceeding.
What could have gone wrong? What can be the things we can look for debugging...?
One of the possible causes of simulation hang is a what is called signal deadlock. It happens where 2 processes are involved, and one signal say A_sig in a process say process_A is waiting for a change in a signal, say B_sig in the another process, say process_B, and B_sig is waiting for a change in A_sig.
If you are working in VHDL, then improperly used wait statements are the most frequent cause of a simualtion hang.
hope it helps,
Kr,
Avi
    vinun_7
it could be with zero delay gate oscillation
If its NCverilog run with this option +ncgateloopwarn +ncaccess+c...
when it hangs.. interupt the simulation(Ctrl+c) then
ncsim> drivers -active
this tells you active drivers.. you add #1 for that cell.
