Simple project help me!!!
ryusgnal
Full Member level 1
Malaysia
Hi i'm newbies in PIC design. I want to built simple project for exercise. I'm using PIC16F877a for this project.
I want to PIC to read data from serial port which i send from hiperterminal. then PIC will XOR the data with '11111111' and send it back to serial port. and i can see the output in hiperterminal. does anybody know the code in C language?
thank you for any help.
ryusgnal,
I have some codes writen in C++Builder 5.03 working with serial port, but it do not exactly what you want, instead, it work under a proprietary frame protocol. If you want it, I may send to you, or post here. You choice.
#use delay (clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6,rcv=PIN_C7)
void main(void)
  while (1)
     putc(~getc());
the magic of ccs pic c compiler....
edit: sorry, i think it was 1-complement... but this is the xor version
void main(void)
  while (1)
     putc(getc() ^ 0b11111111);
Go to Oshonsoft.com and download Pic_Simulator_IDE. This software includes a Basic compiler which generates assembly and hex code. This code can be programmed into a 16F877A or you can use the Bootloader you will find on the site. Or if you like you can run a simulation. Try it it is.
